questions, have you reinforced your kframe? Do you have a sector support kit? Have you locktite your bolts from the box? The first box I got, if you turned the steering wheel one way you can see the box move within the slop from inside the bolt holes. The sector support kit and locktite solved this issue but I already have a reinforced kframe.
