Hello JohnRR,
Thanks for reply.
Not trying to be a wise guy in any way but are you stating from your posts that the cam bearings are not that bad off? Also that the damage/wear that is done isnt going to get any worse? You stated that the cam wore itself into the bearings, which I agree it defiantly did that...
This picture of the back side, bottom portion of the #4 cam bearing LOOKS like there isnt much material left. This was the same on the first failure. However, LOOKS especially when using a borescope can be deceiving..
