Who installed the cam bearings and who installed the cam ?
I doubt you have anywhere near enough spring pressure to have the cam move around enough to do that . Mopar cam tunnels are notoriously tight and out of round on seasoned blocks, if the cam bearings weren't clearanced for the cam that was going to be run when the engine was built then it clearanced itself once it was run.
