Originally Posted By autoxcuda
1/8" of movement is a lot at 3 inches of compression?
I was getting 1/4" toe change per inch of travel on my road course car. Couldn't touch the brakes on corners or it would pull into the turn hard. Installed a bolt and heim joint style tie rod end and got it down to less than .010" toe change per inch of travel, and that problem went away. I don't want to use a heim joint on a street car, though. How do you adjust bump steer on your car?
