The dash frame is looking great, but not finished yet. It does not show well in this photo, but the surface is a transparent black, which is black rust deposited by the process. It is this black rust that under the right circumstances can quickly change to red rust and is called flash rusting. The black rust deposition is a desired part of this process and is a good sign. Apparently too much amperage does not make black rust.
If you don't see two dolphins, you need a vacation.
