Mine are nearly full tight as well. Even Dizusters car on no prep last Thursday at Milan was -8/40 from full tight on the front rebound. Doug
Doug, are yours that tight to keep it from climbing or to give it more traction?
My front end seldom rises more than a foot. The tires stay on the ground the first 6 feet or so. Hooks better tight. Loose just causes it to unload the rear quickly after the hit. If it wasn't in bracket mode I'd tighten it even more. Doug
