Originally Posted By Dave Hall
It sure looks like a spacer sitting there on the left in the second image. The rockers are held in place between two grooves in the shaft for snap rings? The grooves providing ample side clearance?
That so called spacer is there so the side of the bearing
doesnt ride on the snap ring.. it might be abile to be cut
down some but it has to be in there.. then you have to add
that amount to the other side
wave
