It looks as if you could use a spacer on the right side of the rocker in the first image. It looks like the spacer on the left side of the rocker could be moved to the right in the second image. I would try to get them as centered as possible. Maybe the hold downs can move around providing different offsets as to which pedestal they bolt to? Maybe some machining of the hold down is necessary?
