Quote: On some of the spring assemblys there is a 'set' screw for lack of a better term that you can adjust to determine when the lever engages the hook in the snail spring. It actually has some marks or graduations on it. If your spring assy is rusty, etc you will need to wire brush it to clean it up enough to see the marks.
it's brand new,,,I bought the kit. I'll have to take a look
