I ran in kc , had a blast. If I do it again I'd add weight to the back Sand bags so they could be removed. I walked it out on the bit about ten Feet the stabbed it . My first pass spun bad with no nitrous so I knew it wasn't Gonna work . 70 coronet. 440 iron head . 600 lift mech cam, 150 shot. 4.56 gear . Assassin bars. Adjustable ranchos. Bring a lot to top/mid range if wont work down low. Nobody was doing wheel stands that day.
