I thought about leaving in 2nd, but unfortunately my TB won't work in anything else but 1st. I need the TB to build boost.
The motor is pretty weak without the turbo, so it will definitely hook if I turn it down far enough. Just trying to use as much of everything I got to get the car down the track quick.
