Fwiw, I smear permatex ultra black between all four surfaces....... Block, both sides of the tray, pan.
If what you have now is a fairly small leak, you might be able to cure it by really cleaning off the area around the leak, and smear some black "right stuff" all over the top of where it's leaking, and let it cure overnight.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
