When most airfeilds stop offering 80/85 ave gas for sale a lot of the local guys that could use it would buy several 55 gallon barrels and then go fill them up at a local gas station with ump regular and transfer that it into thier airplanes. I had heard some of them comment later when thier airpalnes sat for more then 5 or 6 weeks (at L 26 in Hesperia, CA in the Mojave Desert) the motors where really hard to start, hence my question on how hard was yours to start on pump gas after it had sat for awhile
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
My Comanche sat in the hangar in Hesperia for almost a year before I flew up here to Bend, it was a lot harder to start at that time than when I flew it once a month minimum
![work work](/ubbthreads/images/graemlins/custom/work.gif)
It had a single primer nozzle into one cylinder so it did not prime all six cylinders, once it was warmed up I could start it off the throttle very easily
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
I would shut the motor down with the mixtue control so all the cylinders where dry when the motor quit and no residual fuel in the intake manifold.
