Always use a 6 point socket on the tight ones or it will round off. Also support the breaker bar at the end of the socket so when you push down you keep the socket straight on the lug nut..
What kind of wheel aluminum or steel? Will the heat hurt the wheel? Can you get at the lug with a die grinder(last resort).
