If I were doing it and the intended use I would go with the AIR GAP.. it works great in the RPM range you will ever be playing in.. plus you wont need the steep gear...the only other thing I would change besides the intake and gear would be to add a low first gear in the trans... would be fine for the street and the few times you would go to the track
