I put it on the rear end... the circle part mount yoke and the pick up mounts on the diff housing..that way there is no change in angle as the drive shaft moves up and down... if you have the holes for a snubber the pick up bolts right on
Mike, no room for the collar on the 60, maybe I have a different yoke on the diff than you .
