I am shocked that this is the first I have heard of this conversion. I really like the idea of hiding the module in an old Mopar ECU housing and that the MSD unit has a rev-limiter.
For those of you that don't run a ballast with the GM style module, do you just tie the start and run circuits together?
Yes it dont get much press for some reason (& it is a chebby piece so it needs to be hidden). last one I did with an accell super coil, the big yellow beast with no ballast & it was a killer setup. you are supposed to run a ballast but you have ALOT of leeway on what you can and cannot get by with. yes tie the brown/blue together
