Any guess what the Hp potential of your motor is? Drag only? Gotta love it!
The only thing I can guaranty is if you stick the tires you WILL need wheelie bars!!
Greg; my goal with the build was to have a street/strip car that was able to break into the nines here in Edmonton at 2100 ft.
The parameters I set for the car were as follows:
-Small block
-pump fuel
-no power adder
I have it booked for a chassis dyno session on the 20th of May.
We did have the engine on the dyno, but only pulled to 7000 (not sure why, I wasn't there) but it was still gaining when they stopped pulling.
I really don't want to start spouting numbers because they seem high to me compared to what I have seen on here in the past with simular combinations.
Dyno numbers always seems to turn threads the wrong way!!!
But like I say, will have it on the chassis dyno next week, and hopefully at the track the following weekend.
You guys have any guesses at power based on what you see/hear?
