That thing is screaming for some wide tires all the way around? Why not a 245/60/15 BF Goodrich Radial T/A on all 4 corners with the whitewalls turned in? Maybe even 255 if they're 7" wheels. Otherwise, if you're pretty set on that size, you can rarely go wrong with Michelin.
