I believe the aluminum blocks are 4 grand. There is a member on here that has the aluminum block. I talked to him personally about the issues I had with a iron block & the only problem he had with it was the oil drain back which he corrected himself. Everything else was good. Maybe the aluminum block maybe the way to go.
