This is probably old news to many of you, but I thought I would share it just in case. I went to the swap meet that ICH puts on annually in Indianapolis this past weekend. Kent Ritter was there and I had the opportunity to talk with him a while. The new version of his cast iron SBM block has the motor mount ears cast into the block now. The block is designed for pushrod oiling, but it can be modified (with an under the intake oil line) to accommodate oiling through the cylinder head. Stock cylinder heads can be used. One thing he did mention was that in some applications there may be some minor clearancing needed but said it would be minor. If anyone is interested in purchasing a block or has any additional questions his cell phone number is 585-610-9979. An alternate number is 585-593-5305. He knows that his contact info was going to shared.
