IMO if he keeps messing around and the aftermarket ever blows open for Genlll stuff he's sunk.
Just a side note but he is in the G3 market, he happens to be the guy doing the big drag pak looking intakes that Muscle Motors and Hughes sells.
This is true, also true that one of the bolt holes on mine to mount the carburetor was threaded at a fairly severe angle. No way you could put a carb on it as came.
Minor issue in the grand scheme, but makes you think twice about buying a whole block from the same source.
