Well, since nobody else mentioned it - has the trans crossmember had rust repair done to it? If so, the rear torsion bar anchors in it may not have been installed/clocked correctly. And remember, you shouldn't tighten the LCA anchor nuts until after you set the car down on the suspension to avoid pre-loading the LCA bushings.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
