I've had several low deck strokers. The first two were 452s. I ran a Street Dominator with an 850 TQ on the 1st motor. The carb had several mods. Probably the most responsive combo I've ever ran. Gobs of torque.
The second stroker I ran a six pack manifold with BG Six Shooter carbs. This combo ran great however I think the motor needed some more carb. The total CFM on theSix Shooter carbs was 750 CFM, well below the standard Holley setup.
“So if it’s on the internet it must be true”
Abe Lincoln
