As stated above.........a GOOD .904 lifter should have an .850 wheel. And here is something else to think about, especially if you need an offset cup lifter and are going to bush the block. Go ahead and move up to the .937 lifter. It will have the .850 wheel, costs no more than a .904 and gives a little bit more clearance with offset cups
