I'm putting together a 73 Cuda and want to do the radial tire setup. I have the leaf springs now but can change to any type setup, what would you guys that race these tires suggest. I have Cal-tracts to use if ok.
You need to pick a few groups or classes you would run in and go by the rules. Stock suspension can be very fast
