Originally Posted By Quicksilver440
Anyone ever seen this? I just mocked up two different bell housings I have with an 833 o.d. 4 speed I have and the drivers side bottom bolt hole on the trans is off maybe 3/8" or so. See pics....
I can't see the picture here at work.
Is this the bell housing I sold you ? It had an alum 833 bolted to it when I found it at the junkyard ????
Yep....I don't think the bell is off...it looks like it matches a BigBlock one I have. I think the hole in the trans if off a little.
Did you take measurements of holes between the 2 ?
Do you have another trans case , or another bell ? either way take measurements between the 2 of whatever you have .
running up my post count some more .
