LOL It is not a wheel bearing problem, there is NO support at the spline end of the axle with this type of carrier, the side gear will move around & lets the axle move.
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392 Stock 11.79 @ 114.5
