I have a 8 in converter that flashes around 5000 but I can only go around 2900 on the line before it slides the front tires. It leaves harder stalling foot braking as much as I can but it runs the same ET idling or 2900. I can cut a better light the higher I stall it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
