Sad but mopar seem to be going down ...I have thought long and hard about a big block Chevy. ..1050hp for 17500.00 Chevy and 22500.00 for mopar 900hp ..5000.00 could be used for a really nice glade and veta...just saying. .
WOW!!!!!!!! I'm glad I'm not you and have to pay that much for 900 HP. I'm not big on throwing numbers out there as I never Dyno my engines but I should be in that neighbourhood for a lot less than that.
6000 dollars Keith Black block (didn't cost that much)
2000 " " Callas crank
1000 " " K1 rods and pistons
3500 " " B1 heads, intake, spacers
1100 " " T&D rockers
1000 " " custom cam, pushrods, lifters
500 " " rings, bearings, gaskets
1000 " " custom oil pan, pump, misc.
_________________
16.200 dollars
I may have left out a few things but I also didn't pay that much for several of these items. I do my own work (as you could do too) and I'm always on the look-out for deals. Mopars are only expensive if YOU let them be. Sure Chevy racers have more choices but if you don't like it, join them. I love beating Fords and Chevies. Even more so with my Edelbrock headed small block.
Both are all new parts carb to pan and dyno sheet
Parts I listed are all new too and nobody touches my engines and I could care less about some corrected DYNO sheet. The guy that parks next to me every week bought a chevy Shaffroff engine (shaftjunk) and when he took it apart he couldn't believe his eyes. No thanks.
I friend of mine has a Shaffroff 440 small block chevy in a 2800 lb Mustang and it runs 6.30's on motor, alcohol injected. I am faster than him and heavier. But his has a NOS cam in it. I am sure that is the reason. He usually sprays 500 shot on it and then he is a lot faster.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
