So I finally got the 400BB in the volare running like a beast, but now I am having issues with the trans, reverse is really sluggish to the point of high rpms to move, and 3rd gear sounds like its free revving. I modified the valve body per the transgo TF-2 instructions for the street strip with shift command, I know that the valve body is good to go, since its the same one i had in my boosted slant and that thing was a beast, and shifted gears just fine, I am thinking that maybe the front band might need tightening up, since the transgo instructions say tighten till snug then back off 2 turns.....whats snug ? lol any advice or help is greatly appreciated, first and second shift no issues in auto and manual mode ( courtesy of my hurst V-matic 2) but no thrid just a high whine and like i already said reverse works but high rpms to make her move. also installed my own cable kickdown, used the buchillon for inspiration, and adjusted per there instructions,
Thanks,
-Mike
