Hey guys, finally I am able to throw some accumulated stroker parts at my '71 Satellite Sebring. My first MoPar was a '66 Coronet with a mild 440 (Street Hemi cam, headers, Street Dominator intake, etc.) and I always loved the cruiseability of 3.23 cogs with the Torqueflite. The 499 will have Wiseco 15cc dish pistons and either 78cc milled & ported Stealth heads or the new TrickFlows, so the compression will be roughly the same (10.5:1). I want to run a 2500 stall (11") converter, so it can have a little lope to it, but I will need some vacuum for driveability. I have the largest shelf Comp hydraulic retro-roller cam (242/248-110LSA) and the largest shelf solid street-roller (262/262-110LSA) as well as a custom solid street-roller (255/255-110LSA), both Comp grinds as well. I even have an old Isky 505-T oval track roller (248/248-108LSA) that seems to be a gentle ramp cam but wide lash, low (.531") lift and ancient design. I will be using a RPM intake, 870 Holley carb and 1-7/8" Hooker headers with a full 3" exhaust. Ideas? Thanks in advance! RB
