If you have several psi at the carb inlet at WOT (with an adequate fuel line ID end to end) then your delivery is adequate (tho an elec helps priming) and if your fuel ain't percolating then a return line ain't absolutely required but cooler fuel (from it constantly moving from the recirculating) does help power slightly (every little bit adds up)
