Are you going to put a regulator in the system? I was a little hesitant to do the full blown electrical pump, regulator, relay, oil switch etc. But, once I did the research it made sense and it was not hard. Just have to do your research on wiring etc.
If your going to put in a simple in-line fuel pump you are better off just using the reliable OEM type 6 psi mechanical pump. Works great.
If you are going to an electrical pump. I would make sure it had the right pressure output etc. You don't want to have low fuel pressure at WOT. You could go lean and blow a piston.
