post all you want bro. I think carter has a street pump but wait for the guys that know for sure. In my exp some pumps put out more than they say plus alot of of fuel psi gauges ain't dead on accurate. Sumpin to keep in mind if you have a flooding/high fuel level situation on down the line. Me I like a bypass line back to the tank with a Holley low psi reg regulating a return line T'd close to the carb inlet rather than regulating the fuel TO the carb inlet. keeps the fuel cooler too
