I installed the tank Saturday, along with new tank straps. Generally the tank fits like a stock tank, but the fuel line and return connections come out of the sending unit pointing right at the same area the "J" bolt is for the tank strap. The lines clear, but they are really close to the "J" bolt. I plan to put some fuel line over the "J" bolt threads to prevent any chance of chafing the supply and return lines.
I also changed the axle fluid, trans fluid, and installed new stainless rear brake lines, but that ate up a bunch of time so I did not finish wiring the fuel pump and sending unit.
