Thanks for the replies. Yes the bearing retainer is sized with the bell housing. I also made sure tHe run out was adjusted within tolerance when installing the bell. The trans slides right in.
I will give Jamie a call today. He is about two hours from me. I will run it up to him if I need to pull it.
