Quote: I put together a pretty good combo this winter. Ran 10.90's in good air and 11.1's in the heat. I did have the edelbrock aluminum heads.
Chrysler Steel Crank 6.760 Ohio Crank HBeam's .030 SRP FT 10.5 to 1 Comp Weiand Team G Intake with matched ports Comp Cam SOLID-Very strong mid and upper rpm .016 .018 2500 to 6500 23-232-428 XS282S 244 252 duration @.050 Lift .520 .540 centerline 110º Set it up at 110 centerline 1.5 ratio rockers 1 3/4 header tubes 5000 stall ATI 8" 28 x 9 x 15 slicks 4.10 gear 850 cfm Barry Grant Race Demon
IMO the heads are worth .3 on the track.
AJ
how much did the car weigh, what was the elevation?
