Originally Posted By krautrock
you got the caster and camber backwards
you want as much caster as you can get and less then a full degree of negative camber...
Ha, yes I did, good catch! THANKS!
Changed up top to avoid confusion for others in the future.
I did this at work and apparently didn't pay attention to which heading I was typing in - luckily I decided to post it on Moparts!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
