The MRLs dropped in, believe it or not, John! Btw we did use the offset intake cup lifter and fwiw we used the Hughes Big block Victor Intake rockers to really straighten out the pushrod which is always a kind of sticking point on a lot of w2 builds...took some research to get there but its s nice solution,
. Nice and thanks for the info. I should have my R3 engine done this week and if I'm not happy with how it runs with the solid lifter cam I may look into those over the winter. This block is a 59 degree with the added head bolts so I have some grinding to do
