Originally Posted By MattW
Thank you once again up
Forgot to mention I have a 2003 dakota 2wd with a 4.7.
Are the parts Numbers and the adjustements the same?
22958 for the soleniod?
I believe my trans is the 45fre.
Thx Matt
NO! the 45rfe behind that 4.7 is completely different from the 46re I posted. They do not have band adjustments, just replace the filter and fill with transmission fluid.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
