Originally Posted By MattW
Originally Posted By slammedR/T
Borg warner solenoid (bigger one on left) next to stock mopar solenoid(smaller one on right)
Well thank you too! up
Jut about to change my trans oil and filter.
How do you adjust the bands. popcorn
Matt
If stock ratio lever on kick down band, tighten to 72inch lbs. and back off 2 1/2 turbs for the kick down band(on driver side of case above front oil cooler line fitting. Low/reverse band have to have the oil pan dropped and adjust it to 72inchlbs. and then back off two turns.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
