I wonder how much the difference in the A body exh manifolds would cost him?
Not sure , the factory rated the engine 5hp less than the RR/superbee engine in 69 , everything is the same except the manifolds an the A body has a dual point instead of the single point .
My dart is about 300 lbs lighter than a B body , I did buy a set of 4.30 gears last spring
