So what's a good grease to use on the 8 3-4 wheel bearings? I have some Napa wheel bearing and chassis grease, it's white lithium grease. Then I have some valvoline synpowerngrease which says it's good for wheel bearings as well. But the valvoline synpower has some moly in it. Which one would you use?
