I mentioned it was 4th because it was called 3rd gear.....The fact that it will go into 4th gear and "work" is kinda pointless since like you mentioned the trash run through the trans likely tore up more than just the cluster/input.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
