The 68-70 B-Body Mopar shifter mounting brackets (like I pictured) are designed for the factory Hurst shifter and normally work on all the Hurst shifters.
The main reason for replacing them is because the bolt holes to secure the shifter to the bracket get stripped out.
If the original one on the trans isn't stripped out you should be fine reusing the original one.
Kayse can't keep up at all now. lol
