If you are replacing the mount then just get a sharp heavy chisel and split the old one and the bolts will come right out. I would use an air chisel and that thing will crumble and fall out
Gus
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
