Re: Wiring directly to the battery, how do you do it?
[Re: 451Mopar]
#1773980
03/08/15 12:17 AM
03/08/15 12:17 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Not misinformation. All wires have some resistance and inductance. Just because they are the same "circuit" does not mean the same location. That same common circuit could be broken down showing small resistances due to wire length (and even connections) between each part of the circuit. Having the connections closer to the battery, and on a different connection than the starter or other high current loads will also help prevent dips in the voltage when a high current load turns on. E=I*R
The inductance or capacitance of wire in a DC circuit is nill. When you get into the Ghz, that's a different story.
I agree that being on one side of the circuit vs another can result in higher or lower voltage which is due to resistance of the wire + connections in the bulkhead.
Also when a car is running, the alternator will be the source of the current, not the battery so your reasoning is backwards.
Entire Thread
wesgtx440
03/07/15 07:45 AM
451Mopar
03/07/15 07:53 AM
wesgtx440
03/07/15 05:12 PM
denfireguy
03/07/15 11:24 PM
cjskotni
03/07/15 11:56 PM
AARCONV
03/08/15 03:44 AM
cjskotni
03/08/15 03:51 AM
451Mopar
03/08/15 03:54 AM
Kiddart
03/08/15 04:09 AM
451Mopar
03/08/15 07:08 AM
Cab_Burge
03/08/15 08:21 AM
dvw
03/08/15 01:53 PM
Steve Bryant
03/08/15 02:43 PM
Steve Bryant
03/08/15 02:45 PM
cjskotni
03/08/15 03:58 PM
Steve Bryant
03/08/15 04:17 PM
cjskotni
03/08/15 04:32 PM
wesgtx440
03/08/15 05:21 PM
Dabee
03/15/15 04:58 AM
Evil Spirit
03/09/15 12:44 PM
Supercuda
03/09/15 01:15 PM
cjskotni
03/08/15 04:17 AM
markz528
03/08/15 05:23 PM
cjskotni
03/08/15 07:29 PM
Supercuda
03/08/15 07:29 PM
markz528
03/08/15 11:10 PM
Supercuda
03/08/15 11:19 PM
Cab_Burge
03/09/15 12:49 AM
StrkrDart69
03/09/15 05:14 AM
451Mopar
03/09/15 07:48 AM
dvw
03/09/15 12:22 PM
jbeintherockies
03/09/15 04:32 AM
NITROUSN
03/09/15 04:44 AM
NITROUSN
03/08/15 04:46 AM
cjskotni
03/08/15 04:55 AM
ahy
03/08/15 05:04 AM
crackedback
03/08/15 05:06 AM
NITROUSN
03/08/15 05:41 AM
denfireguy
03/10/15 04:33 AM
beepilot
03/15/15 03:16 AM
RapidRobert
03/07/15 08:47 AM
Steve Bryant
03/07/15 02:20 PM
StrkrDart69
03/08/15 05:27 AM
jbeintherockies
03/09/15 04:40 AM
