(1) adv the cam 4 deg (2) dial in the dist subsystems in order (3) strip kit for the 1406, it's too lean out of the box here & if you're up in elevation it'd be even worse (4) closed chambered heads (mag/302) if you want to go that far. EDIT Google said elev 5,371 feet MORE EDIT with some more thought it might be LESS lean up there (less air) but you still need a strip kit to get richened from the out of the box jetting
