Re: My 318 is a dog, Need to make a change !
[Re: herkamer]
#1773497
03/06/15 08:50 PM
03/06/15 08:50 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
Too much cam
Really?
The 340 cam is a broomstick.
0.442" Exh. Valve Lift; 0.429" Int. Valve Lift; Hydraulic; (050) Duration at .050 Lobe Lift; 220 Exh.; 210 Int.; 114 Degrees Lobe Separation
At this altitude...most of you guys have no clue what a detriment 5000' is. A super hot 318 might run mid to high 15's up here.
Now a cheap fix for what's already there is advance the cam 4 degrees and go with the Rhoads V-Max lifters. Lose about 10 degrees of duration down low and that would really wake up what's there. Angle milling the heads for more compression would also help a ton.
Agree with how elevation can affect performance ![](/ubbthreads/images/graemlins/iagree.gif)
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Entire Thread
MileHighDart
03/06/15 09:59 PM
D_C
03/06/15 10:11 PM
GTX MATT
03/06/15 10:13 PM
MoparJ
03/07/15 12:23 AM
SuperStockWagon
03/07/15 01:00 AM
GTX MATT
03/07/15 01:15 AM
72N96RR
03/07/15 01:42 AM
Steve Bryant
03/07/15 01:42 AM
RapidRobert
03/08/15 10:35 PM
MileHighDart
03/06/15 10:29 PM
HotRodDave
03/06/15 10:44 PM
Paul_Fancsali
03/06/15 11:08 PM
herkamer
03/06/15 11:43 PM
Supercuda
03/06/15 11:48 PM
HotRodDave
03/06/15 11:52 PM
Jerry
03/07/15 12:07 AM
feets
03/07/15 12:15 AM
herkamer
03/07/15 12:46 AM
MoparJ
03/07/15 12:50 AM
StrkrDart69
03/08/15 05:45 AM
Sir Valiant
03/08/15 10:58 AM
dfsmopars
03/06/15 11:34 PM
RapidRobert
03/07/15 02:16 AM
ahy
03/07/15 02:46 AM
GoodysGotaCuda
03/07/15 04:40 AM
Mr.Yuck
03/07/15 05:29 PM
MileHighDart
03/07/15 06:03 PM
Mr.Yuck
03/07/15 06:29 PM
moper
03/10/15 06:10 PM
HotRodDave
03/10/15 08:07 PM
MileHighDart
03/12/15 02:38 AM
HotRodDave
03/12/15 07:08 PM
MileHighDart
03/12/15 07:30 PM
HotRodDave
03/12/15 07:46 PM
Dean_Kuzluzski
03/12/15 11:58 PM
roe
03/13/15 01:09 AM
Geezer
03/13/15 04:13 AM
451Mopar
03/12/15 08:05 PM
MileHighDart
03/13/15 01:21 AM
moparborn
03/13/15 01:30 AM
dogdays
03/13/15 01:55 AM
451Mopar
03/07/15 08:17 PM
HotRodDave
03/07/15 08:39 PM
451Mopar
03/07/15 09:00 PM
Jerry
03/07/15 09:24 PM
Polarapete
03/07/15 09:25 PM
moparborn
03/08/15 06:11 PM
roe
03/08/15 10:21 PM
MileHighDart
03/09/15 12:00 AM
roe
03/09/15 01:00 AM
451Mopar
03/09/15 03:18 AM
MileHighDart
03/09/15 05:36 AM
herkamer
03/09/15 05:46 AM
jeff57
03/09/15 04:51 PM
GY3
03/13/15 04:44 PM
3hundred
03/13/15 06:13 PM
GY3
03/13/15 09:36 PM
franko
03/10/15 05:29 PM
